GordonThree wrote:
A while back in another thread I mentioned buying two 3000 RPM 24 volt industrial fans for using to power vent my fridge on very hot days, to help improve efficiency.
I finally got around to installing them. I went with two Noctua iPPC 24v 3000RPM units, IP67 rated. They support pwm speed control but I'm currently not using that feature.
The fans are installed using silicone pegs? on a piece of aluminum angle stock. I re-used two mounting screws that hold the factory air damper in place.
The fans connect to a piece of 18ga cable which runs down to the bottom of the vent, where it's connected to a 12-24v boost converter and remote switch that is tapped into the fridge 12v supply.
I became overwhelmed by mosquito as I was installing the remote switch and didn't grab a picture. I'll try again shortly. The remote switch toggles on when ambient is above 85F and off at 82F, probably lower than it needs to be but 90-100 degree days are very rare in these parts.
Nice job. :C Love it. Can't get any better than noctua fans. Super quite!
Those are on the bottom?
If so it could be a much better setup. As the heat rises the fans will be fighting to pull air down. If they are on the bottom may I make a suggestion???
Put one in the bottom pointing up at the fins/coils/condenser and the other in the top vent pulling out. It will be waayyy more effective.
