jodeb720's avatar
jodeb720
Painting the Walls of the 5er
My wife convinced me last summer to paint the inside of the trailer.
As I've read multiple times the process is as follows:
1. Lightly sand the walls with electric sander - mechanical adhesion.
2. Wipe down the walls with water
3. Wipe down the walls with TSP
4. Rinse walls - removing the TSP.
5. Prime & Paint.
Tried and true.
This morning I was told that the sanding was never done, and when she was pulling back the painters tape, it was peeling off.
I'm at a cross roads.
She wants to put up wall paper on two of the walls - which will stick to the paint.
My question is this:
Will the freeze/thaw and movement of the walls cause the paint to peel and I'll be redoing this in 6 months or do I need to sand off the paint, and then reprime/paint the walls?
Thoughts?
Thanks
Josh
  • Do it right and do it once. The paint is your base for the wallpaper.
    I wouldn't apply wallpaper over paint that does not adhere to the wall.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 14, 2026
