terryaGJ wrote:
Mbopp - did you run the IOTA output through a fuse before the battery? Did you wire the output of the WFCO through the IOTA DC output to provide path back to distribution panel?
Terry
The IOTA is hard-wired to the battery terminals, no fuse or circuit breaker. Good point though.
I didn't do anything with the factory 12V wiring. The feed comes off the batteries and through the WFCO 12V fuses.
For the AC power to the IOTA I tapped off a 120V outlet in the bedroom, drilled a hole and ran the cable down into the pass-through, and added a switch and duplex outlet.
