nmhuntr's avatar
nmhuntr
Peeling back edpm roof for repair
Here is my issue. I bought a TH 4 years ago and had to do some repair/ sealing of the front right roof edge by the ladder. There was a slight soft spot but i cleaned it good and used dicor on it. I checked it off and on the first year but have been traveling a lot and have not used it in 3 years. I checked it last week and the dicor is not sticking anymore and it has been leaking to the point that I must replace the decking in that corner. Is it possible to peel that portion of the roof back, replace the wood, lay the roofing back down and seal it? I do t know if they glue the roofs down to the wood or not.
Thanks a lot
  • Golden_HVAC wrote:
    Look up epdmcoatings.com
    They have videos on the website, and I coated my rv with this two part product.
    Good luck, Fred.
    How does that help the OP with re-installing his membrane after replacing the wood under it?
  • Look up epdmcoatings.com
    Good luck, Fred.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,363 PostsLatest Activity: Apr 24, 2025
