EnzoColorado
Mar 15, 2018Explorer II
SoundGuy wrote:
does your fridge have a climate control heater (probably does) and if so do you know how to turn it off? If it can't be turned off then you want to add your own switch so you can as that heating element will unnecessarily draw down your battery reserve when dry camping. Conservation is the key. ;)
I don't know the answer to that one, will have to go home and dig up the owner's manual to check, thank you for that suggestion.
If I don't plan to get an inverter, is there any advantage to installing the AGM batteries inside the storage area? We do tend to store a lot things down there and will hate to lose usable storage space. I understand the advantage of mounting the controller as close to the battery as possible. That's why I asked if the controller can be mounted externally. From what I read, I think the Grape Solar 40 AMP PWM can be mounted outside?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
