ScottG
Aug 08, 2017Nomad
That is ABS. Dont use anything except good old ABS cement.
Clean everything well and use the cement. Unless there's some piece missing you dont need to add any material - that will just make the job harder.
Hold in place for 30 seconds after cementing and your done.
It will last forever if done right but if you use some other "glue", it will eventually fail.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
