texnwar
Aug 09, 2017Explorer
ScottG wrote:
That is ABS. Dont use anything except good old ABS cement.
Clean everything well and use the cement. Unless there's some piece missing you dont need to add any material - that will just make the job harder.
Hold in place for 30 seconds after cementing and your done.
It will last forever if done right but if you use some other "glue", it will eventually fail.
The tank is plastic after all, not fiberglass like I first thought. From what I understand after doing some research, ABS or any other cement for that matter may not work. It's suggested to weld the cracks via polyethylene rods.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
