Old-Biscuit
Jan 16, 2014Explorer III
I have dual sinks in kitchen........both connect to one line that runs about 2' before there is a 'P' trap and then after the 'P' trap is a short stub pipe with an 'air admittance valve' on it before the drain line turns 90* and goes to waste tank.
'P' trap doesn't need to be right at sink.
Screw on fittings to sink drains and then glued joints on other fittings.....screwed joints on 'P' trap.
Slip joints not good idea due to vibration/bouncing going on.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
