Ductape_Dave
Jan 21, 2014Explorer
The picture erstanfo is a good example of an offset trap and does not create any problems. It is now a running trap instead of a P trap and does the same thing, sealing out sewer gases. Some European style sinks have no room for a P trap and instead are installed in the wall. The trap nut will not vibrate loose and is good to have to service a clogged drain or access an item that might have slipped into the drain. 20 year master plumber.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
