doughere
Apr 05, 2015Explorer
I have 120 watts mounted on the roof, but have the same problem with camping in the shade.
I have a 100 watt portable (from solar blvd) that I clip directly to the battery. By the time its in the sun and wired up, there is enough voltage drop that I have never had a problem. If the voltage got too high, I'd just disconnect. You could of course just make a connector to connect your portable into your existing controller.
I actually have connectors to tie into the battery, or to tie to a set of battery clips. Panel can then be lent out to friends if they are running low.
Doug
Doug
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 13, 2026
