time2roll
Oct 23, 2013Nomad
I would look at a 600w inverter if max load is 500w. No sense installing big fat wire, fuse etc required by a 2000w.
Transfer switch has two inputs, one output. Inverter to one input, utility power to the other input. Output goes to the trailer etc. It will come with instructions.
You will need a 30a rated switch if the cord has a 30a RV connector.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
