dewey02's avatar
dewey02
Explorer II
Jun 27, 2016
Problem with Counter Extension - Won't fold flat
Yesterday I installed the Camco Countertop Extension.
But when I fold it down, it doesn't fold flat against the base cabinet, it sticks out at an angle.
I have a countertop with an overhang, so there is ample room for it to fold flat, but the bracket binds against itself where the two bracket sections fold together.
I've rechecked the instructions and all screwholes are placed exactly according to instructions and the bracket is installed correctly.
Just wondering if others here have done this install and whether yours folds flat or sticks out at an angle (about 35%). And whether they was anything you did to make it fold flat. Thanks.
  • DrewE's avatar
    DrewE
    Explorer III
    You wrote brackets (plural). Are they separate pieces? If so, are they square and sitting in the same plane and properly aligned with each other?
  • beemerphile1 wrote:
    Did the brackets fold correctly before you mounted them?
    Yes.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
