Redwall's avatar
Redwall
Propane Connections?
OK, again I am trying to build my "ultimate camp kitchen trailer"
Found the right size cargo trailer (6Wx8L)
And now trying to build up my list of stuff that needs to go in/on it...
I want to put twin-LP tanks up front and then run low pressure hard-pipe to everywhere needed.
For the temporary connections, such as the Generator, or a Grill I wanted to put in some "permanent" Quick connect fittings. I can find lots of Quick connect hoses, adapters, etc... but nothing that either comes with its own little access door, or a bulkhead/wall receptacle I could permanently mount in a safe place.
  • I looked when making a hook up for my propane Yamaha and my propane guy told me they were not available mostly because of the size required to allow you to reach in and work with the female side of the quick connect. Ended with permanent mount out of the way with vinyl caps. Bought mine from Propane fittings
