enahs's avatar
enahs
Propane tank cover modification
New style dual tank regulators have a status view window on the front as opposed to the top. This makes it difficult to check the status of the tanks if a switch over has occurred without pulling the plastic cover off. Of course, you can cut a hole in the front of the plastic cover and install a plexiglass piece to serve as a window, but I am wondering whether there is a nifty commercial item that would do the job. I've seen a commercial portal used, but I have no idea where it came from and searches have turned up nuttin. Any ideas.
  • I find it is easiest to simply take the whole cover off, and put it back on.
    Mine slips off and onn very easily.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
