westend
May 01, 2016Explorer
I used copper bar stock, drilled and tapped 1/4" holes in them. You would need a bar of 1/4" thick to handle loads up to 200 amps.
Edit: Let me look around here and see if I can find a piece of copper bar. If I can, I'll drill and tap one for you. I'm going to assume you'll need one 5/16" through hole to attach to a battery terminal.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
