LarryJM
Sep 29, 2014Explorer II
Jozzieo wrote:
Thanks, Great mod, well explained. Sorry about the cut, I would have done the same thing. I think we all hate that noise. I am doing a bunch of mods to my 5th wheel, and have removed my exhaust hood and fan motor.
I will copy your mod Larry. Appreciate it.
The fan motor and resistor you used is OK? Would the other motor have been OK to use do you think?
Thanks, Jozzieo
Well as to fans I only got to try one since as I explained I ruined the more powerful one and while I repaired the blade as best as I could I just didn't want to chance it breaking after being installed so I was basically limited to the 118CFM model one. I sort of think the more powerful one would have been good especially on a lower speed and then in the fast mode while noisier would really pull the exhaust out. Unfortunately, I don't have and can't find the number for the more powerful fan, but one should be able to find it in the Jameco catalog from the specs I gave above.
Larry
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
