ernie1
Aug 28, 2023Explorer
SJ-Chris: Thanks a bunch for the info and clearing a few things up for me as I also am trying to gain more efficiency from my Dometic 3 way fridge.
I'm not going to hijack this thread but I feel compelled to mention only briefly what I have done to gain more efficiency from my fridge. After noticing that the refrigerator in my 2018 PW would always run warmer by about 8 deg.F when it was on propane versus 120v shore power or inverter. Puzzled by this since normally when on propane a refrigerator will usually perform better than when on 120v ac I decided to experiment. I took the jet out of the burner and had it drilled out .003" and reinstalled it. The refrigerator performed much better but I stopped the experiment with this jet because I felt there was too much heat blowing into the burner. This a seat of the pants feeling only.
Next, I bought a new original sized jet for $70 and drilled it out only .001" and reinstalled it . So far I tested it for weeks at a time and I am now at a point where when I'm running the fridge on propane it's about 8 deg.F cooler than when on 120v ac and I'm really happy but am still experimenting. I think I've gained 16 deg.F of cooling. Oh yes, I have three fans in the outside rear and two inside the cooling area.
So that's it. So that I don't hijack this thread and put unproven experimental ideas into others heads which will cause a dangerous condition, I done discussing this experiment of mine.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 29, 2025
