donn0128
Apr 21, 2014Explorer II
Re: Cellular Amplifier & Antennae
Clicky
I have had an amplifier in the fiver for the past three years. To attach the magnetic mount antenna, i simply glued down a piece of painted steel using lots of Dicor to the roof. When i am setting up, i clumb the ladder, drop the antenna on the plate, and feed the wire thru the slide out bulb seal then complete opening the slides. Mine is totally wireless, in other words there is an inside antenna and an outside antenna. It comes with a power supply so all i need to do is plug it in to 120VAC and turn it on. Generally you will not need amplification if you are close to major cities or along major highways. The times I need it is when we are hosting several miles off the highway or in very remote far west locations. Then i am lucky to get 1G service early in the morning. The closest towers are miles away with lots of mountains in the way. And nothing
Will help in those situations.
