AF_ENG_RETD
Apr 25, 2016Explorer
Houston Remodeler has very good advice, only one thing to add is the possibility to use silicone instead of thin set and instead of grout. The silicone will remain flexible as the RV moves. Ensure you use enough silicone for adhesive to the floor to give the tile a good base; use of not enough silicone and a point load on the tile could cause it to crack.
Good luck with your project. A trial run on a separate piece of plywood is the way I would proceed to test any method prior to installation in your RV.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
