Cosmic_Artifac1
Sep 29, 2018Explorer
Lynnmor wrote:
I didn't watch this all the way thru, but it might get you started in the right direction. I have done the PWM and reversing on another brand and it turned out better than factory schemes. video
aha! excellent man thank you...
the motor he has in the video is actually not designed for PWM trimming but it still does work you just can't get those ultra low amp draws and totally silent operation as you can with the motor designed for it... which I happen to have already installed because Fantastic Vent did things right before acquisition by Dometic.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
