Golden_HVAC wrote:
After that, I might change my 26W florescent from 18" tube to a bunch of 12 or 24 LED panels, and see how that works out.
Here is a florescent to LED conversion I did:
This is my main ceiling light, and it works GREAT! I added a push-on push-off switch for the light's main power, and am using the original rocker switch to select the brightness level (rocker selects 3 panels, or all 6 panels).
The blue goop you see in the photo is silicone adhesive - I found that the double sided foam tape that comes on the LED panels often fails in warm conditions, so I have just been forcing a little silicone under the sides or corners of the panels and that solved the problem (the original double sided foam tape is still under there). The silicone is fairly easy to remove if needed. Others have talked about adding screws to the sides of the panels, but the silicone has been working great for me - fast and easy.
I also have a boat which has about a half dozen florescent lights fixtures, several of which are flickering and dim.... so I have begun converting them too. I am starting to use LED panels with 24 each 5050 SMDs (each 5050 SMD actually is a package containing 3 individual LEDs).
Have fun.....
