GASMAN6674
Aug 24, 2016Explorer
Re: low pressure propane Tee - Quick Connect
iagary wrote:
Another question - do you think my LP regulator on my TT would provide enough flow to run both these at the same time? If not I might as well just switch from one to the other.
Thanks for any help.
Don't know what the btu capacity of the oem regulators, But I would assume its not much more than 2-300,000 btu. Add up the btu input from the appliances you want to run at the same time for ex full size grill could be anywhere from 30,000 to 80,000 btu compacts should be on the low end. I work in the LP industry and our smallest change over is rated 450,000. But be aware do to line size,tank size, distance (length of line) and ambient temperature you may not get anywhere near that.
Hope this helps some
