bigbillsd
Feb 12, 2017Explorer
westend wrote:
An alternative is to buy surface mount breakers and wire up the distribution from those. You can make it all look good by mounting the breakers on a piece of aluminum plate. Here's a good place to shop for circuit protection: Waytek Wire. Mounting three surface mount breakers will use about 1/8 -> 1/4 the space of a steel box. If you'll pay the price, the Cooper-Bussmann manual breakers are the way to go, they even sell a sealed Marine type (not necessary, IMO).
Do they make surface mount breakers for 120 AC current? Everything I looked at was automotive, mostly @12 volt.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
