GuyCanRV's avatar
GuyCanRV
Explorer III
Jan 04, 2024
Solved
Troubleshoot fridge problem...
I am trying to revive my Dometic Servel RGE400 fridge once again. I just had the cooling unit repaired a second time (under warranty). The repair guy wrote back to me the following: "your unit ...
  • GuyCanRV's avatar
    Jan 09, 2024
    Well the solution wasn't obvious at all.
    I had to go back to my notes from a couple years ago to get some ideas.
    When I got back the cooling unit then, installed everything and turned it on,
    it didn't work then either.
    I was having problems connecting the control rods at the bottom of the fridge,
    so only installed the ones I needed: thermostat control and gas/off/electric.
    For some reason the far switch was set to gas or off two years ago and that's why
    the fridge didn't turn on. I only use electric.
    So I focused on the controls again. For some reason this time I thought the far switch
    was the thermostat. I turned it to a position I thought would be a good temperature.
    Little did I know I had turned the fridge Off again!
    After I got that straightened out, the fridge still didn't work!
    I was running out of ideas now. A last ditch attempt. I turned the fridge upside down and then
    back upright. It finally worked!  🙂
