NoDak84
May 03, 2017Explorer
Well good news. I found the screws that are holding the floor in. The way they are rusted blends in almost perfectly with the floor.
Got the grinder, after the wrenches failed, and ground off the heads of as many as I could. I'll need to grab another disk after work tomorrow, but I can now get the one section to move about, only a couple screws still holding it in.
I'll be able to get the floor out without actually removing the body. Once the floor is out I'll roll it out to the street and pressure wash all the **** out of the inside. Then I can use the old floor sections as templates to cut new ones. The existing stuff is half inch, so I'll just replace it with the same.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
