dockmasterdave
Aug 01, 2020Explorer
I just measured the run, it is 18'
If I want to extend the 6 GA with another piece of 6 Ga, I will probably need to replace my fuse block.
It is a simple 2 sided fuse block with 2 30 amp fuses and is wired completely with 10 Ga.
I am guessing that since one side/wire is connected to the 6 Ga run to the power center, that runs all my 12 volt in the TT.
Since the other side/wire bypasses the 6 GA run and heads back the trailer it is probably for my non fuse panel related items, IE break away braking and co/propane detector ?
I looked online but didn't see anything like the fuse "block" near my batteries. Any suggestions on where to get one ?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
