ScottG wrote:
Nice but why didn't you use ABS?
I've never understood why they plumb some trailers with separate dump ports when all it takes is a little pipe and a few fittings to do it right!
Well done!
Scott
Local plumbing shop only carry's PVC and they told me the sizes are the same. (My question; then why ABS & PVC?) I used two 45's to allow for any miss alignment. The pictures deceiving as it runs down hill to the front with a bend to the right. The plumbings shop told me the cement for PVC-ABS is different so I bought a can, sea foam green?.
If I would do this again I would use the long sweeping 45s for a gentler bend, nor sure it would make a difference.
Personally I would have paid and extra hundred or so to have this done at the factory. The adapters used to get the rear 1.5" up to 3" for the dump connection & cap cost has to cost close to the same. I did have to make hangers but I had the strapping in my shop.
