Judo_x-ray's avatar
Judo_x-ray
rear end ladder
Hi everyone, I need some ideas. I want to install a ladder on the back of my cherokee 2003 25 ft. fifth wheel. It did not come with a ladder. Any suggestions as to brand,easy install etc. Thanks for the input.:)
  • Ditto on checking with manufacture. After buying my 2002 Sunline, I inquired about adding ladder and was informed that the back wall did not have the bracing for it unless ladder was ordered prior to construction. I just contacted Winnebago about adding a ladder to our new 2201DS. Reply from Winnebago was that a ladder can be installed but will void my warranty. I've responded by asking if it's possible to have it done at the factory and does having a dealer install it void the warranty.
  • Something else to think about...
    Does your camper have a "walk-on" roof? Mine has the ladder, but not the walk-on, have to put plywood down to get around up there. Limited usefulness:(
  • Some campers are "prepped" for ladder installation and some are not. Find out if your is prepped or figure something else out.
  • Contact your manufacture and ask for diagram showing stud location in your back wall. They should be able to email it to you.
  • You better see what is behind that back wall first. The ladder has to have solid support or the fasteners will pull out.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 14, 2026
