RonVBT's avatar
RonVBT
Rear leveler jacks on Ford Chassis
I would like to install leveler jacks on my 2011 Four Winds Hurricane 31D MH. The Ford F53 chassis comes with pre-drilled holes in the frame for the jack installation however Ford put a Fuel Tank hanger right in the middle of the rear set of holes (both sides). I called Equalizer Jacks yesterday and the salesman seemed to not know anything about this. He talked to a install tech and the tech said that they weld a bracket on the frame for the rear jacks. I have several reservations about this answer. First, welding a bracket next to the fuel tank seems risky unless they remove the tank. Secondly, I can't be the only one who has run into this problem, it's a Ford chassis problem... Not coach specific. Thirdly, I see HWH jacks has a spacer to go around the tank hanger (part P34599 spacer and AP35038 hardware kit). The problem is, I can't find this part anywhere. Has anyone addressed this issue?
1 Reply
  • If you have any welding done make sure they disconnect all electrical supply sources, if not they most likely will ruin most if not all of your electronic equipment.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 16, 2026
