- profdant139Explorer IIIJoe, that is a good point. And really, it should not be a light beer -- a stout would have a lot more thermal mass!! ;)
- JoeHExplorer IIIIn looking at your picture, you don't have enough thermal mass in there. Only 1 can of Miller Lite ! more beer and the thermal mass will even out temp changes.
- profdant139Explorer IIIThis could be a major advance in the world of RV fridges -- I will see if I can replicate these results. I have a remote radio bbq thermometer but it does not have a computer-readable output -- I would have to graph it by hand.
Well done!! - BarneySNomadVery interesting!
What are you using to get the above temps and graphs?
Barney - wopachopExplorerWorks awesome. The graph below was the first day i put the cardboard in. That big spike to 45F would happen every time i open the door. You can see the immediate change and i promise i was still opening the fridge a bunch of times.
- memtbExplorerWhile it may not be a substantial improvement....the “cold” air “WILL” quickly fall out of the refrigerator area. As someone mentioned......think of the ping pong balls! One of several reasons we have chest freezers at home and a small one in our 5er! Efficient!
- profdant139Explorer IIISo, this must be the origin of the phrase I used to hear from my mother: "Close the dam fridge!" ;)
I am not sure the OP's invention is accomplishing anything, but he gets a lot of credit for thinking inside the box. ;)
No, seriously. This is the kind of smart "what if" thinking that has driven the pace of technological progress in the last two centuries. The idea might not pan out, but creativity has to be applauded. - joshuajimExplorer IIUnfortunately, cold air flows just like water. When you open the door, cold air will settle and warm air will replace it at the top. Might save a degree or 2 in the crispers but that’s just about all.
- prichardsonExplorerOne potential problem with putting something in front of the shelves to retain air when opening the door is that now you are blocking it from reaching the door bins when it is closed. Things stored in the door will now be warmer.
- ajridingExplorer IIevery little bit helps I guess. Can you tell any difference?
The air is so low in mass compared to food though, this cannot be much, but owners of chest-style fridges know that they are "way more better" when open/close bc the air stays in.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 03, 2026
