SULTINI's avatar
SULTINI
REFRIGERATOR DRAINLINE
When I buy a new rig the drain hose from the Ref. is always routed outside through the ref. vent panel. Every time I take the panel off I have to pull that little ringed tube out then put it back when I close up. The first ting I do is figure out a way to drill a hole to the outside through the floor of the rig to put the hose in and drain it outside forever. As a matter of fact I just did my new FW today.
  • It should have a dip in it to form a "p" trap with the water run off to keep the inside of the refrig. cool
  • Bobbo wrote:
    I hope you sealed the hole around the hose well to keep moisture from getting into the RV through it.
    Always seal silicone
    How does plastic turn to powder?
  • Your drain hose is probably the "new thin cheap plastic fall apart after 4 years" hose like ours was. Replace it with a clear vinyl hose from Home Depot or Lowes. Fortunately there is a cabinet under ours so I made the holes where the propane line goes thru larger and routed it thru the floor. Add a cap with lots of small holes or some sort of screen on the end of the hose so bugs can't get into the refrigerator. Same goes for the hoses routed thru the grille. Only real problem with replacing ours was there wasn't enough room behind the refrigerator to get my hands up to the connection to pull the hose off. I had to push the refrigerator forward about 6" to get to it. Used a hose clamp with the new hose and sealed all the holes. There were a lot of leaves in the cabinet because it can get windy around here so I cleaned out all the debris and put a screen kit on the grille vents. Also, put polyurethane on the floor while the refrigerator was forward.
  • Bobbo's avatar
    Bobbo
    Explorer III
  • In a year that hose will be powder anyway, so nothing to worry about.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Nov 08, 2025
