Eaglescout94's avatar
Eaglescout94
Relocating Fresh water tank
Ive got a 97 Jayco 5th wheel and after my last trip I’m looking to relocating the fresh water tank and possible getting a larger one. The current one is under the futon/sofa inside the living quarters, I’d like to put a new one under the camper, possible above the axles to keep the weight when loaded centralized. Does this sound like a good idea or not? If I relocate the tank I then plan on setting up all the electronics that are under the sofa on a sliding platform to make it easier to access when needed and put a sliding platform or even just leave the space where the water tank was (currently is) open to store whatever. So what’s all of your opinions, relocate the tank or leave it where it is?
  • On the bright side, having your freshwater tank inside the camper makes it better for colder weather camping. Lessens the freezing probability.
  • Way too much for a camper that is 20 years old. Live with it, consider what you like and don't like and get a much newer one.
    Consider how much it would cost to have someone do it for you, then consider what the unit is really worth on the market. There is likely better projects to tackle with a new unit.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 12, 2026
