gon2dadawgs
Jul 20, 2013Explorer
downtheroad wrote:
Try using a piece of fishing line. Slide it behind the mirror from the top and pull it back and forth using it as a saw while also pulling it downward. You may be able to 'saw' through the mastic and remove the mirror.
You can also put tape corner to corner in an 'x' and gently break the mirror and remove the pieces...
(Good luck with it...but the second method is said to bring bad luck..:E)
Hey...I have done that! That fresh air in the Northwest is keeping clever alive! :)
Michael
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
