PatrickA51's avatar
PatrickA51
Removing Dinette Table from Fleetwood 26Q Jamboree/Tioga RV
I have seen this subject before, but can't find it.
We want to remove the step that the dinette is on in our 2005 Fleetwood Jamboree 26Q.
Has anyone posted photos of what was done Before and After? I am wondering if there is plumbing or electrical under the step?
Thanks in advance.
  • IAMICHABOD wrote:
    I have not seen anyone that has done what you are talking about doing to a 26Q.
    Yes there is the water line from the fresh water tank to the water pump and a bundle of wires in a loom on mine,it also houses the table pedestal base that protrudes thru the step up floor.
    I got curious :h and went and looked at my 26Q to make sure,yep there they are.
    Waterline and elect line,going under the floor of the step up.
    Click For Full-Size Image.
  • I can't look right now but I always felt the step was needed to allow the bottom of the coach to clear the tires.
  • If there is a step up to the dinette, it's there for a reason. Probably wires or water lines.
  • I have not seen anyone that has done what you are talking about doing to a 26Q.
