sdianel_-acct_c
Jun 14, 2016Explorer
this might help: from an old post: BCooke has it right. Open the left and right side compartments flanking the TV. The screws in question are close to the front frame of those compartments and can be hard to see without putting your head part way into the compartments. Although the screws are quite long, they only need to be backed out about 3/4" and the wood frame around the TV can be pulled out. the remote sensor receiver has a plug that easily separates. Once the frame is removed, a flashlight will show you the screws holding the TV to the wood frame behind the TV. There should be 2 screws on each side at the bottom, and one each side near the top. Use caution as the flat screen is heavier than it appears, and the wires may need to be disconnected before you can set it down on the dash. A helper is quite useful.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
