RussOnTheRoad
Jan 02, 2021Explorer
enblethen wrote:
Trim fixed to the side. You would need to slide refer out.
What wires are you trying to add?
What is under the refer?
That's a bummer about the trim. I do NOT want to go to all the trouble of moving the fridge just to see if there's someplace to route a couple wires.
I want to add LED lights inside my pantry cabinets to the left of the fridge. I'll take power from the LPG detector circuit under the fridge. If I don't come up the outside of the pantry with the +/- leads for the two new circuits I'll be making then I'll have to route the wiring through the panty compartments which of necessity will have to be a little messy because I can't drill in the extremes of the corners where the wires would be out of the way because the body of the drill gets in the way butting up against the cabinet wall (see photo).
If I could come in from the outside of the cabinet where each of the 5 LED strips will be located (one on each shelf) it would be a much neater looking job and safer as there wouldn't be wiring inside the cabinets subject to getting bunked.
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
