RussOnTheRoad's avatar
Jan 02, 2021
Removing refrigerator trim
Does anyone know how to remove the trim on the sides of a Norcold N1095? I'm want to remove the left side trim in order to see if there is room to run a couple wires through the space...if there is any. I'm not sure what I'll be able to see if the trim is removed, but I'm hoping to see a little daylight between the fridge and the cabinet to the left of it.
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
  • Trim fixed to the side. You would need to slide refer out.
    What wires are you trying to add?
    What is under the refer?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
