rondeb
Oct 06, 2019Explorer
DrewE wrote:
It would be most helpful if you could provide some more background information, such as picture of this little chair, the make and model of class C, that sort of thing.
It's possible that there may be screws or bolts under the carpeting. It may also have nuts or bolts you could get to from underneath (or from a storage compartment), or several other ways of being mounted. Sometimes there are other things integral to the RV underneath the furniture; the couch in my class C, for example, is basically built on the case of an outside storage compartment, so removing it would not leave a flat floor where it was.
We have a 2005 Fleetwood Jamboree 26q. The chair I am talking about is the same little chair that seems to be in all Class C's. It is on a pedestal and the pedestal is flush with the floor. We took the chair part off the pedestal and we can feel bolts under the carpet. Looking to find a way to remove this without cutting the carpet. Someone answered that their bolts went all the way through and you have to have someone on the underneath hold the nut while the nut is removed from above. Others have said the bolts do not go through. Just curious to know if anyone has taken the chair out. I have already ordered a small RecPro recliner so it has to come out.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
