DrewE
Feb 16, 2015Explorer III
Should be quite straightforward; the stove is held in with a few easily accessible screws. You will of course need to cap off or otherwise close the gas line. (It is typically connected to the stove with a flare fitting under the top, which hinges up for access. Some of the mounting screws are probably under there as well.)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
