CA_Traveler
Feb 22, 2022Explorer III
I would wire the converter with a fuse or CB to the house battery wire. I'd also add a fuse/CB from the isolator to the chassis battery. This assumes that the existing wires are adequate for the new charger.
A 50A fuse/CB for a 45A charger might be marginal due to loads and tolerances.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
