BFL13
Feb 23, 2022Explorer II
LittleBill wrote:
I don't remotely understand why you would remove a battery disconnect, to just add a circuit breaker disconnect.
all grounds go to the vehicle frame.
my 12v negative goes to the negative bus barin my power distribution panel.
Except the monitor shunt to batt wire of course.
On the fuse, the RP fuses do not protect the wire so disagree with post about that
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 23, 2026
