westend
Sep 03, 2018Explorer
Dan, I built new wheel wells for my old Starcraft. The originals were destroyed by flats and spinning belts from a previous owner. I threw out the plastic remaining, built a wood frame above the wheels, put aluminum panel in the corners, and installed 404 steel sheets, glued and screwed on to the wheel well frame. 404 is what they use for garbage truck compactors and Humvee armor. I feel a lot more secure with that above my tires.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
