sgfrye
Mar 16, 2018Explorer
Lynnmor wrote:
We wanted to retain the jack knife sofa, so we beefed it up where needed and replaced the garbage foam with good stuff. If the foam doesn't squash to nothing, the gaps are not much of a problem.
im following this post closely.
due to my loud snoring wife sleeps in front bedroom and i sleep on jack knife sofa. i have been using a twin size 4 inch foam cushion to build up the seat side of sofa. helps a little but by morning im usually about to roll off it.
what type of foam did you use in the cushions?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
