Lynnmor
Mar 16, 2018Explorer II
sgfrye wrote:Lynnmor wrote:
We wanted to retain the jack knife sofa, so we beefed it up where needed and replaced the garbage foam with good stuff. If the foam doesn't squash to nothing, the gaps are not much of a problem.
im following this post closely.
due to my loud snoring wife sleeps in front bedroom and i sleep on jack knife sofa. i have been using a twin size 4 inch foam cushion to build up the seat side of sofa. helps a little but by morning im usually about to roll off it.
what type of foam did you use in the cushions?
I live near York, PA and went to these folks for the foam. They will offer your choice of foam by letting you test samples right there and then cut and install the foam into the cushions. I chose about the firmest stuff they had.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
