westend
May 14, 2014Explorer
rrhino2 wrote:You should have two wires that were connected to the WFCO output. Those (+), (-) wires should be connected to the batteries. If the Magnum is powered it should be charging with 13 V + to the battery terminals. Do you by any chance have a disconnect switch, a circuit breaker, or a fuse between the Magnum and the battery? Are you measuring at the Magnum 12V outputs?
I am Removing the failed WFCO WF-9855 CONverter that came with the unit and Installing a Magnum energy 2012-20B INverter on 2011 Fleetwood Terra. Any help would be appreciated. I cut incoming 120v wire before breaker box and inserted inverter, in and out 120v. The 12v wire from converter has no voltage reading. What am I missing? I thought these wire would run directly to the batteries.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
