davisnate
Sep 17, 2013Explorer
Thanks robatthelake. I will look into the connectors. There are a bunch of unused wires coming out of the back unit. I am guessing that these are the "normal" control wires. Right now, my control always goes to Aux. heat, which seems to mean that it thinks it is below 24 degrees (it isn't close), when the heat pump can't be used. The buttons on the control do not work well, either. I took that apart and lubricated them, which helped quite a bit.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
