dieharder's avatar
dieharder
Replacing TV
Finally getting around to upgrading the main television from the heavy anchor dinosaur tv that is in the unit to a flat screen. However, I notice that the plug for the house speakers is a typical phono plug, like headphones, where my only sound output is the more up to date component outputs on the flat screen. Can anyone point me to a good adapter that will be sure to work with a female phono plug to the 2 coloured audio male plugs to plug into the back of the new one? Nothing bothers more than trying 2 or 3 different types before finding one that works.
Thanks
  • Is there an amplifier of some sort involved here? Those RCA audio jacks are line level outputs and won't power speakers directly.
    Also: BTW/FYI Component output jacks also use RCA type plugs but carry only video feed.
  • The headphone type jack. I need a cable with the one female end that this headphone jack will plug into and the 2 coloured ends that will plug into the tv.
  • Describe what you have for the speaker's connection, please. What is on the end of the wires from the speakers?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,396 PostsLatest Activity: Nov 28, 2025
