marpel's avatar
marpel
Replacing Water Heater
Small trailer with 6 gallon hot water tank.
Am considering, prior to next season, replacing it with a 10 gallon.
Is the difference in size that significant, and has anyone done this sort of thing, who may provide advice or things to be aware of?
Marv
  • Thanks everyone for the responses.
    Grit dog - Din't ask if anyone thought a larger water heater would fit in my particular trailer. Just wondering if anyone had done this sort of thing before and if they could provide some "guidance/be aware of" input. If someone has done this sort of thing before (and I wouldn't know without asking), they sure would know how much of a project it is to switch out.
    Marv
    Marv
    This does not seem like the type of query to "phone a friend" over.
    Noone here would have the slightest clue whether a larger water heater would fit in you RV or exactly how much of a project it is to switch out.
    But, I bet you could find the size of one on the internet in less time than it takes to write this post, and then go break out the tape measure.
  • Always curious; why go to larger water heater? More people...longer showers...
  • I did a repair on a friends 5'ver a number of years back. He had a 10 gallon tank that died in a CG we were both staying in. He bought a new unit at the local RV place and I swapped it out for him.
    The tank itself was ok, so I kept it, thinking I would repair it an swap mine out, going from 6 to 10. I wish it was that easy.
    As mentioned, physical size difference.
    For obvious reasons, the 10 is bigger. It requires a bigger opening to fit in. This requires surgery on the wall of the RV to provide solid framing all around to screw the unit in.
    On mine, I didn't have enough extra width and height to make it an easy conversion. I would have had to carve up a partition, do cosmetic repairs and more, so I scrapoed the idea.
    However, if you have enough extra width and height inside, and you're willing to enlarge the opening of the outside wall, yes it is doable.
  • According to the Suburban manual the 10 gal is about 3 1/2” wider and taller and about an inch deeper then the 6 gallon.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
