westend
May 27, 2013Explorer
thegriffins wrote:6 amp is the maximum rating. What does the yellow Energy Star sticker state for yearly use in KWH?
Thank you for responding. I hope I have all of the information you need to help me.
1. The refrigerator is Energy Star. It is a Frigidaire LFHT1817LB6 - 18.2 cu ft - The paper work says 6 amp / 115 volts.
2. The inverter is WIN - 12X20B3RT / output current amps up to 16.7 amps, peak output 70 amps, output continuous watts 2000.
3. We also have a solar panel
4. Batteries are Energizer Deep Cycle Marine/RV - RC180/12 volt / Marine cranking amps 840/cold cranking amps 675/E27DC. There are 3 of them.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 25, 2026
