Bill_Satellite
Apr 04, 2018Explorer II
Planning wrote:samert wrote:
Normally it drains into a pan and then the water just evaporates from the compressor heat.
Occam's Razor baby!
If you were as lost as I was, here's a definition from Wikipedia.
Occam's razor (also Ockham's razor or Ocham's razor; Latin: lex parsimoniae "law of parsimony") is the problem-solving principle that, when presented with competing hypothetical answers to a problem, one should select the one that makes the fewest assumptions. The idea is attributed to William of Ockham (c. 1287–1347), who was an English Franciscan friar, scholastic philosopher, and theologian.
In science, Occam's razor is used as a heuristic guide in the development of theoretical models, rather than as a rigorous arbiter between candidate models. In the scientific method, Occam's razor is not considered an irrefutable principle of logic or a scientific result; the preference for simplicity in the scientific method is based on the falsifiability criterion. For each accepted explanation of a phenomenon, there may be an extremely large, perhaps even incomprehensible, number of possible and more complex alternatives. Since one can always burden failing explanations with ad hoc hypotheses to prevent them from being falsified, simpler theories are preferable to more complex ones because they are more testable.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
